TwinTurbo.NET: Nissan 300ZX forum - injector replacement-- which injectors?
Subject injector replacement-- which injectors?
Posted by jm12rr on May 08, 2008 at 10:33 AM
  This message has been viewed 231 times.
Message Hi all.
Background:
I have a '90na which has been intermittently not firing on the drivers-middle cylinder (not sure of #). after not finding time to diagnose the problem for ~6mo., i finally just took the car to the local nissan dealership and let them diagnose the problem. They said the injector on that cyl is bad (haven't checked the resistance myself though) and want $1200 to replace it. since the car is almost 20yrs old and has 100k miles on it already, i'm just going to replace all of the injectors myself. i have read the tech article posted and everything seems quite straightforward.
Question:
What do i need to purchase? it seems like old-style, stock injectors run ~140 each new, but aftermarket injectors that flow more can be less... this doesn't make sense... What do i need besides the injectors? would it be worth it to upgrade the fuel system at this point?
any info/suggestions would be greatly appreciated!
thanks in advance,
-john
